Stephen Bort
- Feb 17, 2004
Howdy, folks, have been nosing around here and projectorcentral, and still have a few questions that I hope you can answer for me.
1) When they say that a projector runs at 36 db, is that a sound reading right next to the projector? Or from a set distance away? If a projector is four feet above your head, is the sound particularly annoying?
2) I’m guessing that most people have their projectors set up so that some keystone correction is necessary. I’ve heard that the extreme is 30%, but what is considered a normal angle? Is 25% too much on an entry level projector? Is 15% too much?
3) Is the only way to adjust the size of the image to move the projector further or closer to the screen? Is there a way to make a 90” projection and “squeeze” it down to 60” to increase resolution? (In other words, will an entry level ($1500 or so) projector look better the smaller the image gets?)
Thanks!
Thanks!
