Christopher Dopp
- Oct 18, 1999
I recently purchased a B&K AV2500 II Amplifier and want to have it turn on when i turn on my receiver. The Amplifier has a RCA jack on the back labeled CTRL-IN which is designed to allow remote switching of mute on/off. The amplifier will operate when a 5-24V signal is applied to Ctrl-In.
I have purchased a 12V 1000mA Power Adapter from Radio Shack and some RCA jacks that attach to the wire with a screw. I planned to hook up the screw on RCA jack to the adapter wire, plug it in to the CTRL-IN jack and hook up the adapter to the switched outlet on my receiver.
One problem I have is that the output from the Power Adapter has two wires (+ & -) but the amp only has one RCA jack. I assume that i am to only hook up one of the two leads to the RCA jack as it only has one screw connector, but I'm not sure.
I don't want to damage my amplifier so I hope someone can help me.
Should i just connect the RCA jack to the postive lead and hook that up to the Amps CTRL-IN? Am i supposed to hook up both wires to the RCA jack?
Any suggestions would be appreciated
