MikeDierbeck
- Apr 15, 2002
Hello
Well, I have used Avia and have all of the speakers (including the Sub) calibrated to 85dB from my seating position. As I stated above, when I used an 80Hz crossover for all of the speakers, the dialogue didn't sound too good. However, I messed around a bit and got good results with the following crossovers:
Front Speaker Crossover > 90Hz
Center Speaker Crossver > 60Hz
Surround Speaker Crossover > 80Hz
LFE HIGH CUT FILTER > 80Hz
I have the LFE set at the maximum which is 0dB and all of the speakers set at small.
My question now is, are these crossovers all right in giving me very good quality sound? I know sometimes that whatever SOUNDS good to us really isn't the correct levels that are systems should be at. Are some of these x-overs too high? too low?
I've read Guy's thread about the warble tests and the low frequency tests, but I"m not exactly sure how to run them correctly? When I do the warble tests, my results fluctuate from 74dB up to 80dB, down to 75dB, up again to the low 80's, back and fourth everytime. Is this all right?
Also, when I do the low frequency tests, it starts at I think 200Hz and works its way down. How do I use this function? is this what I use for the crossover frequencies?
Thanks for ANY help whatsover. Right now, my system sounds good to me, but I want to make sure I"m setting the crossovers correctly.
Mike
Mike
