Jose G
- Aug 18, 2002
Are you sure it's on all the time? My green light stays on for awhile after bass is sent to the sub (It's more than 7 minutes, because I've waited for 7 minutes. I assume it's more like 10, but I'm never that patient to wait to see when it shuts off- it just does. When I come back to look it's off). Also if you put it to on first and then go to auto mode it will stay on for a long time before it goes out.
The phase switch: In phase (0) the sub is facing the same direction as the mains. Out of phase (180)- the sub is facing the mains. Many set it to what sounds best- although many can't even tell the difference between the two. A way to check is to have someone flip the switch for you and you stand at the listening spot to see if you hear a difference.
