Thomas_Berg
I have been considering the RAVA and the Hsu VTF-2, but i was milling around on onecall.com and saw some being offered for
And at $499...the ct150 is also a really good deal.
i once owned a 15" sub and it seemed slow in response to the music. is that a general quality of larger drivers? it went really low and sounded good, but i would have traded it for a 12" anyday. i'm going to circuit city (ooh, divx still hurts) tomorrow to check them out. but is it normal for larger subs to be slower in sound delivery?
(btw- it was an MTX 15" for the car)
I do think independent performance verification like this is a valuable INDICATOR of the subwoofer's capability's however. There's many that disagree with me and think objective data is worthless though...different strokes I guess
Well, I don't see how anyone can justify the contention that such data as Nousaine's provides no useful information whatsoever, although I wouldn't choose a sub based solely on how loud it can get at certain frequencies. Were TN to measure my dual-Tempest IB, he may very well find that it measures very similarly to the Hsu TN1220HO/500 watt amp combo I had installed in the same room/corner, but they certainly don't sound the same to me calibrated identically . I wonder what other measurements might be useful to quantify the sound we hear from a sub.
That wasn't my intent, and if it wasn't clear, please forgive me! Rather, it would be like going to the Dodge dealer, and asking to ride along when they measure the Viper's performance at the track. Not just some other magazine or 3rd party, but see the measured performance yourself.That's kind of degrading to the whole concept of having independent reviewers (who AREN'T manufacturing COMPETING products)measuring/listening too/reviewing the products to begin with I think? said:Quote:
I'd look at things like transient response, for starters. How well does the system track a sine burst? This is often what people refer to as "speed" of a system. A system that tracks transient inputs quickly. That is, when the sonic burst is finished, how long does the system keep generating signal? If I put a a 5 cycle 40 Hz tone burst into the system, how much delay is there before it reaches 90% of full amplitude output? Likewise, how much delay is there when the burst ends, and the output of the system settles to 10%?
Additionally, there's the entire sub/room interaction thing, which is the primary reason Mr. Linkwitz advocates dipoles! Heresy to some (I'm sure several on this board) to build a sub with NO enclosure and limited bass "SPL capability", nevertheless many well respected researchers and designers adhere to this design, because of the quality of the bass, especially in room.
Then there's the issue of group delay, which again shows correlation between perceived quality and system designs.
Lastly, I'd also look at the distortion spectrum itself. close-spaced twin-tone sweeps are quite instructive about the distortion spectrum of the driver. MANY drivers exhibit peaks in the distortion spectrum in the 300-600 Hz range, while better drivers push that down lower, where's it is not as audible. They would measure the same THD, but to your ear, the driver with the lower peak spectrum would sound cleaner.
If I sounded like I dismissed Mr. Nousaine's works, please let me correct myself! That was not my intent at all. He's collected some very important data, if for no other reason to get a good handle which subs can linearly displace more air than others.
Rather, I wanted to take the position that max SPL at various frequencies is not all there is to subwoofers, and that in my opinion, there's not too much correlation between max SPL and audible accuracy, especially with music (as you've noticed with your IB... ).
Dan Wiggins
Adire Audio
I certainly didn't read it that way, Dan, I'm sorry if it seemed like I was referring to you.
Those values which you mentioned are what I had in mind, and would have to be included before we can say with any degree of confidence that a sub's performance can be described by a "comprehensive" set of measurements.
