des0free
- Aug 9, 2010
- des
I randomly inherited and combined the AV components listed below. I would like advice on whether this is a sensible combination for listening to music CDs and watching DVD videos, and digital video/music files, or whether some components are "poorly matched" and would be sensible to improve upon? (which component(s) most limit the performance? perhaps the cheapo dvd/cd player?) - Polk rti12 speakers Woofer three 7" Diameter (17.78cm)Polymer Composite with Rubber surround Midrange two 5-1/4" Diameter (13.34cm) Polymer Composite Dynamic Balance with rubber surround Tweeter one - 1" Diameter (2.54cm) Silk/Polymer composite dome Overall Frequency Response 18Hz-27kHz Nominal Impedance 8 ohms Recommended Amplifier Power 50-500 w/channel - Harmon Kardon HK3485 receiver 120.0 Watt - 8.0 Ohm - THD 0.07 % - 2.0 channel(s) ( Main ) - Kenwood SW-32HT powered subwoofer 8" downward-firing driver fed by a 100 watt amplifier, bass-reflex, includes a volume control, crossover level control, and line-level inputs - Sony DVP-NS72HP dvd/cd player (was a cheapo player?) Connected by HDMI to TV & RCA stereo audio cables to receiver) reads the data on a standard DVD at 480p, 12 bit video d/a, 16 bit audio d/a) - Cinematube digital media player (up to 1080p HD, connected by HDMI to TV & RCA stereo audio cables to receiver) - Sony Bravia KDL-40SL130 40" LCD connected by HDMI to DVD player Native Resolution: 720p Contrast Ratio: 1600:1 Display Resolution: 1366 x 768
