Theodore
- Feb 7, 2002
Im considering buying one. I have an old vcr and I would like to upgrade to a dvd player. I don't do a great deal of recording though. Thanks for any feedback.
As well, a new multi-format standard may arrive, allowing for the DVD-RAM/DVD-R/RW drives to write to any three of those types of discs.The Multi Format was approved quite a while ago. Panasonic will be releasing a PC multi burner in October. It's already been demonstrated at tech shows.
Anyways, I'm looking to get myself a Panasonic DMR-E30 soon... maybe.
In a few months, DVD+R may be compatible with set top players, but you may have to pay twice the price for a DVD+RW disc.They already are, though as they're newer than DVD-R a bit, the media is more expensive, but the compatibility as noted above is similar to DVD-R, not necessarily better as advertised.
