I'm trying to crunch some numbers to see if I can come up with a reasonable design for a transmission line project. My starting point is the D'Appolito designed Thor project for SEAS. I'd like to change the taper ratio of the line from 3:1 to 4:1, while increasing line length and internal volume.
What I'm coming up with so far looks like this:
Internal dimensions
45.25" H
8.5" W
19.5" D
123.33L/4.35 cu. ft./7526.27 cu. in. V
4:1 taper ratio
roughly 100" line length (?)
extra fold in the line
line ends at bottom rear of enclosure
I'm thinking of eliminating the base, but I'm not sure where I would place the crossover (I do have a few ideas, though). Don't hesitate to tell me if my math stinks, because it's an issue I'm already aware of . Also, this is the first time I've ever tried to do anything like this, so it wouldn't surprise me if I'm way off base in my thinking.
Questions:
Using the same drivers as the Thor, what kind of low frequency performance do you think I can expect? (I've run some numbers using formulas and a calculator, and think I have a general idea. The tentative numbers look pretty good.)
Will I be able to use the same crossover design as the Thor, or will it need to be modified?
Will the line opening up on the bottom rear of the enclosure negatively impact on the sound of the speaker?
To take a look at a breakdown of the original design and its process, click on the audioXpress Thor review (written by the designer) link on the Madisound Thor page.
http://www.madisound.com/thor.html
Internal dimensions
45.25" H
8.5" W
19.5" D
4:1 taper ratio
Questions:
