Andrew W
- Jun 19, 2001
I have a cheap sub and until I can afford to replace it with an SVS box, it will have to do. It is an "always on" model and it has an slight hum. Can I replace any components such as caps or transistors to attempt to alleviate this noise?
BTW: all components are plugged into a single Monster A/V power strip/filter which then plugs into the wall. I don't have cable or satellite TV either.
Good quality cables all around.
Andy
Andy
