Any acoustic advantage to "tinning" the ends of my speaker cable? (1 Viewer)
Cees Alons
Cees Alons
No.
But it might come in handy to assure you're using all the strands and none of them shortcuts to the other wire.
(On some connectors it might also make it slightly less handy to bend it to the proper curve.)
Cees
Wayne A. Pflughaupt
Corpus Christi, TX
Wayne
What you might do is tin just the very tip of the wire, not the whole thing down to where the insulation is stripped back. This will eliminate the “strays” and still leave the flexibility, if you need it.
Wayne A. Pflughaupt
John Pine
John Pine
Good tip, errrr...I mean good idea. Thx Wayne!
Does it matter what type of solder I use?
Allan Jayne
Use solder intended for electrical/electronic work, typically 60 tin 40 lead rosin core.
Do not use acid core solder or soldering paste. Solid solder may work also but it is more difficult to work with because without flux (rosin) it won't tin the wire as readily, and lower tin mixtures and non-lead mixtures require a higher temperature soldering iron.
Video hints:
When soldering transistors, IC's, and other semiconductors, get the lowest melting point solder you can, even if it contains lead.
TheThrillisgone
