Mike_Ch
- Nov 26, 2001
I acquired a new Rotel RB-993 3*200W power amp yesterday. I have it hooked up to a Denon 2801 receiver, and use a Pioneer DV535 DVD player as a transport. The sound has been great (I will post a review of it soon), but unfortunately I now have a very annoying hum/buzzing noise coming from all the speakers connected to the power amp.
I have tried unplugging/plugging all components in and out (btw, I don't have cable tv) trying to isolate the source. With the Rotel amp plugged in, I get a very slight hum from the speakers which I cannot hear from the listening position (nevertheless the Denon never had this problem). I assume it is just the transformer humming?
More disconcerting is the buzzing noise. If I hook up any interconnect to the DVD player and connect it to the TV (S-video) and receiver (coaxial) I get a buzzing noise which I can hear from the listening position. If I don't hook up the interconnects from the DVD player to the end components (that is, one end connected to the DVD player and another on the floor) I don't get the buzzing noise. Turning off its power-point switch (not the one on the player, but the one the mains socket is connected to) also eliminates the buzz. The TV and receiver alone do not cause the buzzing noise, it is only when the DVD player is connected to them. I have tried using different cables, but they all cause the same problem. What could be causing the buzzing noise, and how can I fix it? Plugging the DVD directly into the mains socket does not help either (it has a 2 prong cord if this helps).
The DVD player's warranty has just expired, and I don't want to buy another player after upgrading the amp (I'm still still a poor uni student!). Please help me, I have no idea what could be wrong!
Mike
Mike
