That and over the air antenna.What do you just stream now?
Unfortunately it doesn't work that way.Actually if the fiber cable works I could then get another to run for the arc correct? Any downside to that ?
Great. It must lift the ground. That was a solution I used way back when, but I just used a “cheater” plug, which can have risks.So I plugged the cable box into the No hum and it really didn’t work. I then plugged the AMP into the No hum and it completely eliminated it! I have the cable box and PS5 running to the receiver and the ARC from my receiver into the EARC of the TV. How do you feel about ARC? Do you think it is the best option or do you lose something? My receiver is a Sony STR DN1060 and my TV is Samsung S95B OLED. Do you think it would be better to run everything to the TV and use an optical from the TV to the receiver?
