A speaker in a coke can - could it be? (1 Viewer)
Javier_Huerta
As I was looking at this Coke can, I realized I could built a pretty weird speaker out of it (don't ask me how I came to realize this fact - I guess the meeting I was in was too boring).
What do you think? Is it possible? I have looked for little woofers in Parts Express (I guess I'd need a 2" driver) but I can't find any.
It'd look very cool. Now imagine it with a small tweeter on top. :)
Cam S
Would the coke can make it sound incredibly harsh and tiny, as the thin aluminum would reflect and boucne alot of the sound. A coke can isn't exactly a dead enclosure. But what do I know.
Javier_Huerta
Cam, what if the inside of the Coke can was sprayed with sound deadener, or had foam in it?
The reasion I'm asking is, Sonotubes are often used for subwoofers. A Coke can seems to be an excellent enclosure for a small speaker. I can imagine it, with a couple of small stands, painted with a metallic lacquer and and clearcoat, with a small tweeter on top.
I guess I'll have to find a small enough driver for my tests.
Javier_Huerta
A tweeter would make the thing like an R. Crumb cartoon of a B&W Nautilus, I think :)
I'll try it. I mean, how much can a decent 2" driver cost?
Javier_Huerta
Crush a coke can in your hand. Now try crushing a sonotube. I think it should be obvious why a coke can would be a waste of effort.
Well, yeah... but the Coke can wouldn't be dealing with a Tempest, or a Maelstrom. It'd be home to a nice little 2" driver...
How cute. I could build mini-subs and sell them with a note saying "My dad is a Tumult" :D
Dan Hine
That isn't the point. The point was that one creates a rigid enclosure that is not likely to add coloration to the sound produced. The other does not do this. I'd much rather use PVC pipe like these. ;)
Brett DiMichele
Brett
I would just use a piece of 2" PVC and cut out a 2" piece
of 3/4" MDF and hot glue it inside the tube on the backside
add some binding posts and put a deflex pad inside and a
simple lowpass capacitor and run a decent full range driver
and woolah bose killer.. (It doesn't take much to kill bose)
Javier_Huerta
TimForman
I'm still thinking aluminum can, aluminum driver. Say it with me, "aluminum can, aluminum driver".
Brett DiMichele
Brett
I say someone should make a sub out of one of those Phart
Pipes you see on all the Hondas these days.. Heck most of em
are at least 7" OD..... :)
Randall Duncan
Ooh!! Creative audio! I think I'm gonna get me some PVC pipe
and put together some speakers using those little 2'' speakers
from Parts Express... Because I have 24 of them! :D
webbhcjr
