skylark68
Your questions and thoughts are very interesting. I'm learning quite a bit from your posts. Wish I had the knowledge you seem to possess from your posts. Very intriguing material.
I can't find the remarks in the WideScreenMuseum regarding the aspect ratios only affecting the bottom of the 35/4 image.
Whether using a 4 perforation optical reduction print or an 8 perforation Eastmancolor contact print, the recommended projector aperture ratios always maintained a common headroom with varying aspect ratios using more or less width in the case of 8 perf, and always sacrificing the lower part of the frame in both 4 and 8 perf formats. Maximum useable image width was dictated by the size of splices in the original 8 perf negative.
Probably not Roland but 1.33 projection was touted by Paramount when VV was released.
Hopefully theatre owners in 1953/4 were not so silly as not to upgrade at least to 1.66.
"touted"? Why would they promote 1.33? You will not find 1.33 mentioned anywhere for the promotion of VistaVision.
The finders on the VistaVision cameras carry a hairline framing marking in the aspect ratio of 1.66/1. There will also be a frame line marking for the 1.33/1 aspect ratio. The cameramen are instructed to compose for a loose (meaning adequate head-room) 1.66/1 picture. A picture composed in this way will play equally good at 1.85/1, it will play very satisfactorily at 2/1 and it can be played at the old standard of 1.33/1.
At the bottom of the same page, Marty writes:
"The only prints made from VistaVision negatives that were the full 1.33:1 aperture were made for television rather than theatrical presentation."
There were a number of aspect ratio's that were mentioned in various booklets that were never used. See the one below for MGM Camera 65 - later called Ultra Panavision. "3.14 to 1" for Cinerama or Road Show - never used
As much as I love it. it's sometimes it's hard to remember exactly WHERE specific information is located!
In this case, the info can be found at the beginning of the VistaVision "specs" section under "Camera Aperture and 4-Perf Print Specs."
He writes:
Now, as I read this again...he MAY be referring to the fact that there is wasted information at the bottom of the horizontal frame regardless of how it is projected. This is the first time I read it that way as, to my mind, it seemed like he was saying the lower portion of the frame was sacrificed when changing aspect ratios. I see now that it is POSSIBLE he is just referring to the superfluous info at the bottom, but why, then, would he mention common headroom?
It IS mentioned in the booklet Paramount sent to exhibitors in 1954 as one of the options:
A transcription of the full pamphlet can be found here: http://www.widescreenmuseum.com/widescreen/vistavision.htm
"The finders on the VistaVision cameras carry a hairline framing marking in the aspect ratio of 1.66/1. There will also be a frame line marking for the 1.33/1 aspect ratio. The cameramen are instructed to compose for a loose (meaning adequate head-room) 1.66/1 picture. A picture composed in this way will play equally good at 1.85/1, it will play very satisfactorily at 2/1 and it can be played at the old standard of 1.33/1."
"As a further recommendation in this regard, it is our belief that in the very large theaters they should install screens capable of accepting the aspect ratio of 1.85/1, unless the sight line for seats at the back of the main floor is limited by a low hanging balcony. In this case the theater may elect to install a screen in the ratio of 2/1. This is the only limitation that should force the theater into an aspect ratio as high as 2/1. In theaters where the screen width is limited to under 30 feet, and where there is adequate height, we recommend a screen aspect ratio of 1.66/1, reducing the height only when necessary for good viewing."
I think this makes it crystal clear what Paramount's intentions for aspect ratios were regarding the presentation of VistaVision. This actually makes a good case for the 1.66:1 aspect ratio for home viewing, as our home theater screens are rarely going to be 30 feet wide, much less exceed that. A case for 1.78:1 could also be inferred from this, using the maximum screen width available and not having "adequate height" to accommodate the entire 1.66:1 image. However the 1.66:1 aspect ratio is definitely not what would have been seen during any full 35/8-perf VistaVision presentation (nor 1.78:1).
True, but I'm afraid with this particular title, this release is probably the best we're going to get with it. Hell, I'm surprise we even got this widescreen BD release which is why I bought it on HD Digital a while back.The problem with 1.66:1 at home is that people use screens that are 1.78:1 and wider both in projection and with TV's. Just about everbody will just get a smaller picture with a 1.66:1 aspect ratio, not a taller one, same height and less width which is not what was intended. Going by the VistaVision recommendation it would make the most sense to show this in 1.78:1 on smaller screens, therefore using their maximum width and height for the biggest impact, and 1.85:1 on bigger screens. Take your pick of what constitutes a bigger screen at home and also figure in field of view. When I get my disc I will play around with this a little on my projection system.
It would be great if somebody could redo the soundtrack to include the perspecta mix - must be rather cool when all those engines are first only being heard on one channel and then on all of them!
I agree completely, and was thinking even before you replied that 1.78:1 would be the best use of the available real estate (1080x1920). The statement I quoted just makes it a little easier for me to accept the 1.66:1 that we got and have to live with. If I had my time machine handy I certainly wouldn't be going to see "Strategic Air Command" at a smaller theater where the 1.66:1 recommendation applied (if any theaters even regarded that early recommendation). It would be the rare showings of the full 8-perf VistaVision with Perspecta sound that I would be hunting down.
Just a thought. I wouldn't advocate this for 1080, but with 4k I think it might be kind of cool to have the option of applying masks to crop the image (especially when projected) to give us some of the control that the theater operators and projectionists had when SAC was in theatrical distribution (essentially build and apply our own aperture). It almost sounds like I'm saying "It's my TV and it should look the way I want it to look," which makes my skin crawl when I hear it from someone else.
