Don.l
- Apr 9, 2005
- Don
Building HT and will have a Runco projector and Stewart Firehawk screen, and will be running 5.1. In the framing stage still so still early. Questions:
1. Game Consoles: Should I investigate wireless controllers or should I try to get longer cords for the controllers. The consoles will be in the AV rack at the back of the room. If I get longer cords could I run them under the carpet or something? What have some of you done?
2. For my AV rack I am planning on building a partition wall that will allow me to walk behind the wall to access any and all wiring. I don't need anything of these fancy racks that come out and spin and stuff. I just basically need a shelf system that will house about 6 components. I plan on just framing for and drywalling an opening to house the components. Anybody done something like this on the cheap side? I'm really not into spending $600 on an AV rack.
3. I will have a pretty small HT about 10' X 22'. I will try to get two rows of two for seating. The second row I will build a riser for that row. How high should I build the riser? I was thiking of making the riser out of 2x4's and then using a 1" sheet of of plywood that would raise it off the groud around 5"-6". Anybody got any ideas?
4. Center Channel: Above or below the screen? I know I could drop more money and put it behind the screen, but that's pretty pricey. What do you all think sounds the best, above the screen angled down or below the screen and angled up?
That's enough for now. I'm still in the framing stage, and even though it's hard, and sometimes frustrating, it is fun, and I know what the end result will be.
Don
Don
