OrdinaryMan
- Nov 27, 2007
- Joey
Hello,
I have what might be a dumb question. I hope I can get a definitive answer either way. So I have the Samsung LN52A550 LCD (52") TV. I have been wanting to mount it on a bracket but am having trouble finding a bracket that will support this.
I found a bracket that attaches to an LCD stand. The manufacturer says it supports flat panels up to 50". When I look at the specs for this bracket it seems it would support the my 52" TV just fine. The specs are found here. The bracket arms extend 28 1/2"' max. horizontally and 18" max. vertically. The mounting screws on the back of the TV are 24" apart horizontally and 16" apart vertically.
So my question is this....What's stopping this bracket from working? Everything is under spec for the stand. The TV is well under the weight the bracket can hold. I know I'm missing something but just don't know what.
Any feedback would be great.
Thanks!!!
Thanks!!!
