terence
- Nov 8, 2002
2,800 watts total from Sunfire. Do you think this is over kill? What are you guys thougths?
Here are the Cinema Seven Signature
specs......
Feature and Specs
400 watts rms continuous per channel, all channels driven into eight ohms from 20Hz to 20kHz with no more than 0.5% T.H.D.
800 watts rms per channel into four ohms
1600 watts rms per channel into two ohms – time-limited basis
Two output options for the main left and right channels: current source for a warmer, more open tube sound or voltage source for all the tight response this awesome solid state amplifier can deliver
Intrinsic frequency response one Hz to 80 kHz
Signal present auto-on switch senses input signal on any channel and automatically powers up
12VDC trigger input with 1/8" mini jacks as well as plug-in screw-terminal strip
Balanced XLR and unbalanced RCA inputs
High-quality five-way binding posts
Dimensions: 19" wide, 6.5" high, 15.75" deep
Five-year parts and labor warranty
Architectural model:
Standard 17" width allows installation in standard rack systems
17" wide, 5.9" high (including feet), 16.7" deep (to tips of connectors).
http://sunfire.com/cinemaseven_signature.htm
specs......
Feature and Specs
