Nothing to see here.
Mini also updated. Nothing to see there either.
For a studio owner sure it’s not a compelling switch. But to wave off the whole launch of their most popular laptops and new supercharged and lowest cost desktops as nothing to see here couldn’t be further from the truth for the rest of the world.
I agree. The base Mini is a barn burner of a steal. I'd probably spend the $200 for 16GB, but that's going to be more than most people ever need or want.For a studio owner sure it’s not a compelling switch. But to wave off the whole launch of their most popular laptops and new supercharged and lowest cost desktops as nothing to see here couldn’t be further from the truth for the rest of the world.
The Pro version stops making sense very fast though, considering the base model Studio. Especially if you're looking for GPU power. I mean, just upgrading to 32GB gets you so close to the Studio it might not make much sense.
I would get a refurb base model Studio and call it a day. Trust me, I have it, and the extra two CPU cores aren't going to make a difference.Yes, if you're looking for GPU performance, but what exactly do people do on the Mac that makes that much use of GPU though? Apple's not known for hardcore gaming afterall where GPU's definitely needed (and has been by-far the #1 use for that... at least in the Windoze world). OTOH, an M2 Pro Mini can have 12-core CPU vs the 10-core lesser-per-core(?) CPU of the base model Studio... even though memory bandwidth will still be lower.
Seems to me like the lines are so blurred that it maybe doesn't make too much sense to shop for either of them at this point unless you definitely need the machine w/in this next month or so. IF you already have something that serves you well enough (that's lesser than both a suped-up M2 Pro Mini or a base M1 Max Studio) so you can wait, might as well just wait for the M2 upgrade to the Studio instead -- then, even if whatever M1 Max Studio is definitely more than enough power for you, you could be saving some $$$ to get that instead...
Me? I'm wondering if I shouldn't just get a M2 Pro Mini to get my feet wet in the Mac world, LOL... but even the base model for that ain't exactly cheap -- and I'd probably want 32GB RAM and 1TB SSD, but at that point, I might as well throw in the higher core count too, LOL, which brings it all to $2.2K and right where the base model Studio is... so I don't know, especially since I don't actually need a new machine more powerful than my current Wintel-based one...
Probably what I should do is consider a used/refurbed base model of something M1-based... or maybe a refurbed MacBook Pro perhaps (since I don't currently have a working laptop nor iPad of some kind)...
_Man_
You need to check real world performance by people using the software you propose, rather than speculating.I don't know about that. IF I spend the $2K-plus to get something like that, my most likely use would be video editing/processing, which does make use of extra cores -- also, I imagine 12-core (plus faster cores) should be better for whatever other multi-tasking/processing... although again, the RAM (and/or cache?) performance/bandwidth is lower to offset at least some of those gains.
That was actually largely why I went w/ my current Wintel-based (or rather, WAMD-based, LOL) PC 3 years ago to run something like DaVinci Resolve (amongst other things)... BUT, as you know, my life has been turned upside-down since then, so I haven't even touched Resolve (or anything else that needs the extra power) the last couple years... BUT if I'm gonna spend that kinda $$$ and basically relegate my current machine to 2ndary duty, the extra CPU cores (and faster-per-core performance) probably would be desirable even if not absolutely needed. Just don't know whether the 12-core M2 Pro would actually be better than 10-core M1 Max. I don't see why choose the base model Studio over the suped-up Mini if that's the case. Would there be significantly better expandability w/ the base model Studio? Doesn't seem like it offhand.
Anyway, as I also said, I actually don't need a new, powerful machine upgrade, but just mostly intrigued by Apple's recent offerings to consider finally getting my feet wet...
_Man_
$599 base model and done. You are so stuck in the Windows mindset and influenced by maniacs like me and Ron you are overthinking it. Get a cheap mini and add a 2tb thunderbolt ssd. Seriously the base RAM is fine. You aren’t doing 3d rendering right? You aren’t gaming on it? Base ram is fine.Me? I'm wondering if I shouldn't just get a M2 Pro Mini to get my feet wet in the Mac world, LOL... but even the base model for that ain't exactly cheap -- and I'd probably want 32GB RAM and 1TB SSD, but at that point, I might as well throw in the higher core count too, LOL, which brings it all to $2.2K
