I want to use the Cambridge Soundworks p1000 sub with a y adapter using 2 different amplifier outputs. I obvious plan to have the opposite amp off but is there any problem?
It should be fine. If both head units were turned on at the same time, I suppose there could be a chance that it would cause damage. So keep that in mind.
