jeff lam
I ran over my tempest sonotube ideas over to Dan at Adire and he said:
Anyway, for your design, I'd look at 18" diameter tube, 72" high. With 1.5" thick endcaps inset, you're looking at ~287 liters of internal space. After driver and vent displacement, you'll be around 275 liters net.
I'd tune to around 17 Hz. To do this, and to use flares, I'd go with two 4" flared vents (like our FP4 kits), each with a 17" effective length (overall actual length is 18"). They will equal a 5.66" diameter vent, and are
considerably lower cost than the 6" vent flares (which are available from other suppliers for around $50 for one pair). It is plenty of venting for your application.
What do you think of this design, it's pretty big @ 6ft high. I'm not sure if I want to go quite that high, I may have to use 20" sonotube instead.
Anyway, I know many of you used a single 6" as apposed to 2-4" flared ports. What is the advantage to this(actual sonic difference, not air flow and speed)? Also, where can I get a 6" flared kit and how much do they cost?
Thanks!
