JorelB
Grip
- Dec 8, 2000
Hi, I'm thinking of upgrading a 10 year old Sony 27 inch. Maybe to a Toshiba 27A41. Only thing I'm not sure of is will their will be a big difference. Nothing wrong with the TV now 'cept sometimes it goes black, but a quick power off then on fixes that. Plus it takes about 10 minutes for the sound to work. Also it misses around an inch of the picture on all 4 sides. So I guess there are somethings wrong with it But the pictures still fine. Im just worried that when I buy the Toshiba that I won't see a difference since it's not a Wega, cause I hear those are real good but too expensive. I prob said too much already, so I guess what I really want to know is will there be a big difference between a Toshiba with component input compared with a 10 year old Sony with composite(I think it's composite the 3 wires with one video and 2 audio) Ok I'll shut up now
Your help is much appreciated!
PS I got a Toshiba SD1600 DVD player so I can use the component
