Problem with TIVO (1 Viewer)
Michael_Victor
I have had TIVO for about 4 to 5 months now and recently, I have been recording shows that right after they finish recording, they delete themselves. I don't understand. Last night I was clearly recording "Two and a Half Men" because I saw it on my record list. I went back after it was done and it was gone!!! I have space because my system usually deletes an older show. Any help is great.
Stephen Tu
This was in your "To do list"?
Do you have a lot of episodes of that show already on the Tivo, and a "keep at most n episodes" & "keep until I delete" set in the options of the season pass? That seems the most likely culprit.
Michael_Victor
i have some, "Until I delete" shows but I also have alot of yellow or shows with the yellow and the ! mark. so I figured it would just kick off the older shows when I record a new one. I just found it odd that it would delete right after it finished recording.
additional note, (didn't mention because I didn't want anyone to assume right off the bat, this was the problem).
I have had the phone disconnected for (according to tivo) 21 days, but this problem only started occuring 2 days ago. I wouldn't think this would be it but I guess stranger things have happened.
Stephen Tu
The only time it should delete immediately after record rather than an older "!" show would be if you have a "keep at most" on the show.
Pamela
Go to "to do list," then go to "view recorded history." It will tell you why a particular show was deleted or did not record.
papill6n
