Curly
- Feb 20, 2012
- Kurt Sligh
It works but the sound comes from the TV, not the good speakers.Robert_J said:So does your Blu-ray send audio to your sound system? You say it works but then it doesn't. I'm not following.the Blu-ray works but I can't get my non-tv speakers to work.
The reciever tuner (basically a radio I guess), uses the good speakers.Robert_J said:The speakers work with the TV tuner or the receiver's radio tuner? You need to be more specific.Well, they do work with the tuner.
oops, I have hdmi running form TV to blu-ray, not from reciever to blu-ray. But I do have one running from TV to Reciever. And Jason, what exactly do you mean when you say "switch audio and viseo at the reciever"?Jason Charlton said:There's no reason you should be using ARC for Blu-Ray. I'm guessing you have your Blu-Ray connected directly to the TV via HDMI. The Geek Squad is telling you to run optical from TV to receiver, but that's a REALLY bad idea, because you'll definitely lose lossless Blu-ray audio, and will likely lose all digital surround audio, too. You should connect the Blu-Ray directly to your receiver via HDMI, then run a second HDMI cable from receiver to TV. The TV in a home theater setup should really function as a monitor. You run a single video feed to it, and switch both audio and video at the receiver. That's what the receiver was designed to do, and if you've sprung for a nice receiver and killer speakers, you have no reason to go back and use the 10W cardboard POS speakers in the TV.
