How can I get "real" 5.1 sound when I can only connect stereo sound from tv to hometheatre (1 Viewer)
schan1269
HTF Expert
Chicago-ish/NW Indiana
Sam
IF you have RealTek(which is what I have)
The second option(assuming you don't have a USB Bluetooth) is "Digital Output".
When you click that it will show the HDMI and(if it has one) an icon showing L/R digital headphone(which means mini-Toslink).
schan1269
HTF Expert
Sam
When you click headphones...
Does it branch off as analog and digital?
If not...no mini-toslink
If yes, it does have mini-toslink.
retaeht
Edward
Also, the Aiwa has 6 input jacks (for 5.1 surround). Are you sure I can't have real 5.1 on it?
schan1269
HTF Expert
Sam
In that case. You can(helps to mention all available inputs).
But...the "cost" of buying a USB to 6 channel adapter(you could have bought a computer with one already) isn't cheap.
Well, it is, if you buy junk.
http://www.amazon.com/GWC-Technology-AA1500-Channel-Adapter/dp/B003SA9E1A/ref=sr_1_1?s=pc&ie=UTF8&qid=1394743186&sr=1-1&keywords=usb+6+channel
Third of the way to the Denon...
http://www.amazon.com/Vantec-External-Channel-Audio-Adapter/dp/B004HXGJ3S/ref=sr_1_5?s=pc&ie=UTF8&qid=1394743341&sr=1-5&keywords=usb+5.1
And you need three of these...(whichever one you get)
http://www.amazon.com/Hosa-Cable-CMR206-Stereo-Adapter/dp/B000068O33/ref=sr_1_2?s=electronics&ie=UTF8&qid=1394743400&sr=1-2&keywords=1%2F8th+rca
And...your computer has to support 5.1(just because it has HDMI doesn't mean it does...check your specs. There are add-on software you need. Ubuntu and a 5.1 renderer if your current software doesn't have one...and your current software, if one isn't there...has to support one you download)
papill6n
