topcatskin
- Dec 31, 2023
- abby
see subject line , thanks
Typically, stereo receivers have nothing to very little in speaker configuration. Some have a subwoofer crossover. Some have an impedance switch. Many don't have either. So it would be helpful if you clarified your question a bit.see subject line , thanks
Help please! I have a home theater system with an anthem MRX 710 receiver, apple tv box 4K , sonos, blue ray and samsung HDTV with paradigm speakers for music...all run via comcast box. My video and audio are shot and I can't play any CD, Sonos TV or via the apple box. I assume my 10 year old receiver is broken even though the display lights up. I'd like to replace it with the MRx 740 BUT don't know if when I replace it if i have to reprogram my universal remote used to control everything or can I just replace it and play it as if nothing happened? Thanks Gary
It should work, but it won't have all the features/buttons of the new receiver.Help please! I have a home theater system with an anthem MRX 710 receiver, apple tv box 4K , sonos, blue ray and samsung HDTV with paradigm speakers for music...all run via comcast box. My video and audio are shot and I can't play any CD, Sonos TV or via the apple box. I assume my 10 year old receiver is broken even though the display lights up. I'd like to replace it with the MRx 740 BUT don't know if when I replace it if i have to reprogram my universal remote used to control everything or can I just replace it and play it as if nothing happened? Thanks Gary
