Konstantinos
- Jan 26, 2014
- Konstantinos
Hello all.
I've come across what seems like an audio authoring error in the UHD of this Arrow release.
First of all, I play my UHDs in my computer, either with VLC or MPC.
Now, let's take the theatrical version for example.
It has 6 audio tracks:
I don't understand why there are duplicates of the 5.1 and 2.0 track.
Also, if you select one of the first 2 tracks there is an error.
At around 25'-27.10'', the audio starts from the beginning of the film with the main titles music and doesn't match the visuals of course.
Has anyone else noticed that?
the last 2 are the commentaries.Disc Title: ROBIN HOOD: PRINCE OF THIEVES - 4K UHD
Disc Label: ROBIN HOOD UHD
Disc Size: 95,110,693,527 bytes
Protection: AACS2
Playlist: 00100.MPLS
Length: 2:23:12.750
Total Bitrate: 73.21 Mbps
Video: MPEG-H HEVC Video / 62681 kbps / 2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 10 bits / HDR10 / BT.2020
* Video: MPEG-H HEVC Video / 76 kbps / 1080p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 10 bits / Dolby Vision / BT.2020
* Audio: English / DTS-HD Master Audio / 5.1 / 48 kHz / 2022 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 768 kbps / 24-bit)
* Audio: English / DTS-HD Master Audio / 2.0 / 48 kHz / 1052 kbps / 24-bit (DTS Core: 2.0 / 48 kHz / 768 kbps / 24-bit)
Audio: English / DTS-HD Master Audio / 5.1 / 48 kHz / 2024 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 768 kbps / 24-bit)
Audio: English / DTS-HD Master Audio / 2.0 / 48 kHz / 1054 kbps / 24-bit (DTS Core: 2.0 / 48 kHz / 768 kbps / 24-bit)
* Audio: English / DTS Audio / 2.0 / 48 kHz / 256 kbps / 16-bit
Subtitle: English / 29.777 kbps
