jdiddy
Grip
- Sep 17, 2006
- Justin Reaves
This is my first post here so please bare with me. I have recently purchased some home theater equipment and I am not for sure if I have set it up correctly. Let me give you a brief description of my room and then what equipment I have then I will ask my questions. I have setup my theater in my living room which has 3 walls; there is no 4th wall it just opens up into the kitchen/dining room area. ( I know this is not ideal but it is the only place I could setup this stuff. I would have preferred a dedicated home theater room) As for room size its about 19ft long (including the kitchen/dining room area) by 19ft wide and about 8foot ceilings. The actual living room area where my speakers etc are installed is about 16ft long by 12ft wide with 8ft ceilings. I have a Onkyo DV-CP702 dvd player, a Onkyo TX-SR703 THX receiver, 7 ¡V SVSound SBS.01 speakers and 1 SVSound PB12-Plus/2 subwoofer. So I calibrated my system using avia and a spl meter. I set my receiver to 00 ¡Vdb and then calibrated everything to 75db one time and then 85db another time. At this time I believe it is calibrated at 85db and my speakers are Front L 0db, Front Center -3db, Front Right +2db, surround right +2, surround back right +8, surround back left +10, surround left +3 and the sub is -12. All the speakers appeared to have the same output using the spl meter. This was the first time I ever calibrated my system using the avia disk and spl meter. When watching movie¡¦s I set the volume to -15db on the receiver but some of the dialogue is just to low and the sub output is low to. I end up having to bump up the sub to -3db and the front¡¦s and center to +3db. But that is still a little low with the volume set to -15db.
Questions
1)Is the room just to big for these sbs-01 speakers?
2)Does it look like the numbers are anything close to looking ok?
3)Should I re-calibrate the system again?
4)Should I just turn up the volume on the receiver a little more say -10db?
I do like to listen to some of my movies loud but when I have company or my girlfriend is over we don¡¦t turn it up. I do like to however hear all the dialogue etc and not have to second guess what was said ya know?
Thanks for all your help.
Questions
