firebrick
- May 1, 2007
- mark
I am going to be using 7002's as my fronts for my theater. What do I need to know about placement of these beasts? Do I need to keep them out from the walls a certain distance? Due to space I had them placed directly side by side my large rptv, about 6 inches away from the tv on either side. I dont know if this affects the sub quality or not. These things are confusing since they are firing out the front, back and sides. Any suggestions? Keep as much space as possible around these things or put them in the corners? Thanks.
Second question, what do you think of bp2xs for surrounds and bp8s for rear surrounds? Should I get BPXs for all surrounds or just stick with what I have? I am trying to get kick A$$ sound and am finally preparing the room to do it.
Last question, I also have a def tech 15 inch sub that I used before I had my 7002s, would it be overkill to use this sub as well? Should I run the LFE to this sub and just turn the fronts on LARGE? Any suggestions appreciated.
Room is 14x19.
Room is 14x19.
