doug zdanivsky
Ok, let's see if we can get a consensus..
There's 2 camps for the following 2 issues..
Is THIS the ideal configuration:
http://tinypic.com/ih731g.jpg
With the speakers proximal to the listening area?
Or is this the ideal (and if not ideal at least acceptable):
http://tinypic.com/ih73hk.jpg
Keeping in mind the size of the room (dimensions available in the 2nd diagram I posted), the walls, etc..
Also, IF ambient sound is preferred, and you are currently using Paradigm di/biploes for surrounds in a 5.1 configuration, do you use di/bipoles as well for the rears, firing right at each other, like the 1st diagram I posted..
Or do you use direct firing monopoles, say Studio 20's even though the goal is ambient sound?
Thanks for any and all input!
