Do any of you think it’s a bad idea to activate the Erase Data function on your iPhone, if you 10 failed passcode attempts? It protects you in case you lose your iPhone or it’s stolen.
I back up my iPhone to my MacBook, so it's no problem for me to recover all the data stored on the phone.Do any of you think it’s a bad idea to activate the Erase Data function on your iPhone, if you 10 failed passcode attempts? It protects you in case you lose your iPhone or it’s stolen.
If someone has your PIN and your iPhone, they have everything. (As the WSJ originally reported.)One thing: a thief can't just disable Find My Phone w/out also hacking your Apple ID used for the phone, so it isn't just as simple as hacking the passcode on your phone to disable that.
_Man_
Ok, that does suck... and sounds like a loophole Apple needs to close.
I wonder when that loophole (w/ the recovery key) was introduced.
If a thief shoulder surfs and manages to both steal your passcode as well as your iPhone, they can change your Apple ID password from your phone in a few seconds without hacking or knowing your current Apple ID password.One thing: a thief can't just disable Find My Phone w/out also hacking your Apple ID used for the phone, so it isn't just as simple as hacking the passcode on your phone to disable that.
_Man_
I think Gruber addressed this on his latest Talk Show.If someone has your PIN and your iPhone, they have everything. (As the WSJ originally reported.)
Always been. Intentional design choice by Apple. Balance of security and risk to people from forgetting their password. There's been a lot of discussion on this the past month or two since the WSJ report came out.
