RCPJohn42
- May 16, 2010
- John Billig
I have a brand new Pioneer VSX30 and an B.I.C. F-12 sub-woofer. I am having issues with the sub-woofer preout on the receiver. My question is if I run the front speaker cables to the sub-woofer speaker terminals and then from the sub-woofer to the speaker terminals to the front speakers, will the sub-woofer work the same as if I was using the one sub-woofer preout from the receiver? I don't want to go through sending it back for repair/warranty if the sub will work the same by using the speaker terminal inputs/outputs. If so, how does this work? Does the front speaker signals pass through the sub-woofer and the sub-woofer extracts just the bass? Will the receiver need to work any harder or will the sub-woofer amp handle the power to the bass sound on its own, since it is self powered. Do you loose anything from hooking them up this way. I heard if you hook up the sub this way, I need to turn the fronts to "large" in the receiver programing and turn off the crossover on the sub, as the receiver crossover will take over. Do I need to adjust anything on the receiver with regards to crossover? thanks in advance. John
