Alowe
- Feb 7, 2007
- Andrew
Sorry for the lengthly post, wanted to get it all out.
I am a bit new to this...
I have been reading much on calibrating speakers and subs. My setup is a 5.1. the AV is a Denon 2807, the sub being a SVS PB12-Plus, with Ascend CBM340se fronts and center, and 170se surrounds. In what I have been reading, it states to set the master volume on my receiver to 00db, which I believe to be 100% volume, is that correct? Also, I am reading that I should run the gain FULL UP on the sub, again 100% max volume. I am very confused as I feel that this is 100% volume and do not want to damage any equipment. I have figured out how to adjust the speaker levels on the AV, just want to know a little more on SPL how to and setting the sub up properly on the subs panel. Here is what I have read in a nutshell and a little more clarity or a link that better explains what to do would be great! I have a Galaxy CM-140 SPL meter. I also have for calibrating Avia and DVE.
Make sure your receiver/processor master volume is set at "00 dB" or other easy to remember level; it will become your "reference level", one very close to that intended for home theaters by Dolby Labs. And finally, set your subwoofer amp’s volume control. Note here, if you have a "PC-type" subwoofer put the volume/gain knob to no more than 1/4th to 1/3rd of the way up. If it's a separate pro-type amp (like the Samson amps we sell) for a CS-type subwoofer, run the gain FULL UP (it's a different sort of amp design after all and expects to be set up this way). It’s a good idea to check the subwoofer level control of your receiver before you begin the test tones. Keep the receiver's subwoofer output control to about 25% up or lower than "0 dB" (or say -6dB given a typical receiver channel limits of –12 dB to +12 dB) . This will allow your amp to work with the cleanest signal possible from your receiver, while still leaving plenty of downward adjustment you can use from your viewing position (using the remote). As the tones start, alternating, speaker to speaker (watching your sound meter now) set each speaker’s volume to 75 dB or 85dB (depending on your tone source), using the receiver’s channel controls. Not all test disks or receivers are the same when it comes to calibration tones however, if using a test DVD like Video Essentials should allow you to calibrate reference level at 75dB. Ovation's "Avia" DVD is recorded at a higher level to improve signal to noise ratios during calibration, so you need to measure instead to 85dB for all channels if you use it and not Video Essentials (discussion below, regarding a "boost" to your LFE still applies but you simply add the bump you want above and beyond 85dB, vice 75dB).
