Phase error when calibrating (1 Viewer)
thijazi
Tareq Hijazi
I am setting up my new Denon AVR-X2700H AV receiver with a set of Bowers & Wilkins M-1 home theater surround sound speakers in a 5.1 channel configuration. The subwoofer I am using is a Rel T-7 sub which allows me to hook up in LFE mode as well as a high-level mode simultaneously.
From the REL T-7 user guide:
“Both the speaker level and the LFE input can be used simultaneously. This means you may set it up for the best possible 2-channel performance sound with your CDs or other stereo signals and instantly revert to using the Sub-Bass System as the dedicated LFE component when watching movies.
This is a feature of real benefit if you wish to play music in stereo mode in the purist audiophile way and also in REL Theater Reference mode with no switching necessary. By connecting BOTH High Level and .1 concurrently and setting your processor to “Large” or Full Range, the best possible performance will be obtained.”
Here is a sample diagram from the REL manual that describes this connection:
Denon’s AV Receivers come with Audyssey’s acoustic correction technology, MultEQ, built in so I went ahead and tried to calibrate the system using the supplied Audyssey microphone.. When the calibration process starts to measure the speakers output a phase error is reported in the both the front speakers…
When I remove the REL connections from the front speakers the phase error goes away, I am puzzled now, do I simply ignore the phase error reported? Should I reverse the cables? I am not sure if this normal behavior when connecting speakers and sub in this manner.
I am aware this is not a standard setup for most, but keen to hear if any users have any experience with this to help guide me through this.
JohnRice
Bounded In a Nutshell
A Mile High
REL is a good company, but this suggestion is mostly ill advised and extremely poorly explained. First, if your music is sent to the receiver digitally, which it probably is, there is zero benefit to doing what they suggest, and multiple negatives. In that situation I suggest using only the SUB output from the receiver, setting the speaker crossovers to "Small" and 150Hz for starters, because those are extremely small speakers, and playing music on "Stereo" mode will send frequencies below 150Hz to the sub.
If, and only IF your music source is analog, then yeah, doing this would add an additional level of AD/DA and could degrade the sound. The best solution is to keep your music digital until it gets to the receiver and just forget all that stuff REL is suggesting.
thijazi
Tareq Hijazi
I think I am leaning to towards your suggestion, seems far too involving for questionable benefits....
Nielmb
