bgamb24
- Feb 1, 2010
- Brett
I would be MOST appreciative if any of you could lend me some advice. We are currently remodeling the media room to switch from using a 65" Pioneer Elite pro-730hdi to an as yet undecided projector. The ceilings are 9' and will be using a Chief SL-150 projector lift which will be mounted flush into the ceiling. The ceiling is white and the walls are beige. Room dimensions are ~ 16'4"X21'. Screen will be placed one of the 16 sides. Light control will be perfect. Content will be almost exclusively blu-ray with the occasional comcast HD movie rental. I am considering a DLP projector (Optoma 8600, sim2 D80e, marantz 15s2. I also cannot decide on the best screen size, although I realize it will probably have a Hc grey screen and be between 96 and 106". Projector/screen recommendation would be greatly appreciated. I also realize that regardless of which combo I decide upon, placement will be tricky, as most of the DLP projectors are not very horizontally forgiving.
The contractors have completed repositioning the speakers and remodeling the component rack. They are REALLY pressing me for a decision ASAP. Again, any advice would be greatly appreciated.
One last question, would $6000 for a Sim2 D80E with less than 100hrs of use be a good deal?. Also, it seems that while the Sim2 and Marantz models might be better quality units, the models are almost two years older than the Optoma. I found the Optoma online for $4485.
