It all sounds good, with the modification Josh suggested.
Anthem is an excellent, long term solution for a receiver. In fact, I plan to get an Anthem preamp/processor in the next few months.
One slight modification. I know there is the whole "ported subs are best for movies" blah, blah. However, I personally suggest that for $400 more you get dual SVS SB4000s instead of PB3000s. The 4000 line is a significant step up from the 3000. Last year I migrated from ported to sealed subs (dual SB-16 Ultras) and will NEVER go back to ported subs. A excellent sealed sub has many benefits over ported, and the idea is just to get a sealed model with the output capabilities you need.
I'm sure @John Dirk will be more than happy to regale you with his pleasure with his dual SB4000s. You can also read his review HERE, or mine HERE.
