Rob Ritch
- Jun 5, 2002
I have just added a new sub to my system and am curious about where I should set the crossover on the reciever. My equipment is as follows
Denon 2802 Receiver
crossover 80Hz, 100Hz, 120Hz
Mirage AVS 200 mains / surrounds
Freq Range 90Hz - 20KHz
Mirage AVS 100 Center
Velodyne VX10 Subwoofer
Freq Range 36Hz - 120Hz
I was thinking that since the range on the Mirage are 90Hz - 20Khz and the sub is 36Hz to 120Hz that I should set the crossover at 100Hz which is half way between the mirage low end and the sub high end, but I hahve also read alot of recommendations to set the crossover at 80 for HT applications. What do you guys recommend?
Denon 2802 Receiver
