StevenK
- Jul 16, 2000
I've recently had the fortune to demo several low to mid range receivers in my house. I was running an Onkyo 676 and wanted to upgrade to get the latest features. I started out with the H/K 520, moved on to the Yamaha HTR-5560, borrowed a Sony DE-1085 for a few days, and just got the Pioneer VSX-D811S in 3 days ago. The H/K and Sony is gone, so I can really only do a true direct comparison between the Pioneer, Yammie, and good ole Onkyo. I hope this would be of interest to some people, because not quite all of us can afford a Outlaw 950/770 combo I also notice that people then to be very bias towards their own receiver when giving a newbie or not so newbie buying advice...so I'll try my best to be objective, as I haven't really settled on any one receiver. But I'm sure some bias will show through.
I know people have different priorities for choosing receivers, so I'll try to break it down into smaller sections. I'm a movie person and rarely sit down to listen to an entire CD from beginning to end (I usually do chores around the house or whatever...), so I'll try to not throw terms like "it widens the soundstage dramatically." For true sonic performance, the only reliable judge is your ear. So I'll try to make this more a comparison of features, ergonomics, etc....
My setup is as follows:
Fronts: NHT 2.5i
Center: NHT AC-1
Sides: HTD Level3
Rear: HTD Level3
DVD: X-Box
Price (shipped to N. Cali)
Onkyo TX-DS676 $359 refurbed from Ubid
Harman Kardon AVR520 - $627 from Onecall.com
Yamaha HTR-5560 - $359 from JandR.com
Pioneer VSX-811S - $317 from BSLess.com
Sony DE-1085 - $566 from local BestBuy
Build Quality Impressions
1 – Onkyo. Built like tank. Thick Aluminum fascia.
2 – Yamaha
3 – Pioneer
4 – Harman Kardon
5 – Sony
2-Channel Music (no sub, using the receiver's DAC. All 5 had a direct pass-through mode though).
1 – Onkyo – What can I say…I just prefer the sound of Onkyo. Very neutral, solid bass, defined highs. I like it.
2 – Yamaha – A little brighter than the Onkyo, but not harsh.
3 – Harman Kardon – At first I thought it was warm and smooth…but after a month, I felt it was a little too warm and colored. Some tracks became a little tiring.
4 – Pioneer – Didn’t stir me one way of the other. A little bright. Didn’t feel it was capable of driving the NHT 2.5. I think a victim of weak internal amps….though it could all be psycho-acoustics
5 – Sony – Driving Bose…couldn’t tell jack sh!t. Kidding aside…lacked oomph (i.e. meaningful bass) and static highs. I honestly think it’s the speakers more than anything else.
5.1 performance (with powered subwoofer)
1 – Harman Kardon, DD/DTS/DPL II performed as expected, Logic 7 viable alternative to DPL II, no I am nowhere near enamored with it as some seem to be.
2 – Yamaha, DD/DTS/DPL II performed as expected
2 – Pioneer
2 – Sony
4 – Onkyo, no DPII a big minus
6.1 performance
1 – Pioneer. DTS-ES Discrete is improvement over Matrix
2 – Yamaha. Lack of DTS-ES Discrete minor annoyance.
3 – Sony. Has both DTS Matrix and Discrete, but I couldn’t tell one mode from another. Not implemented well.
4 – Harman Kardon. Lack of DD-Ex MAJOR annoyance.
5 – Onkyo. No 6.1 available.
Remote
1 – Onkyo. Learning, well laid out, nicely balanced, macros. Excellent remote.
1.5 – Sony. Nice learning remote. Not quite as well laid out as the Onkyo, but just as powerful.
2 – Pioneer. Not learning, some codes don’t
4 – H/K. Learning remote with built in SPL. Very powerful with macro ability, but useablity is down the toilet. Lay out is horrible! Tiny buttons. Not worth the aggravation.
4 – Yamaha. Not learning, but plenty of codes.
Looks
2 – Onkyo. More buttons than I prefer, but fairly simple, “mid-fi” look.
3 – H/K. Elegant, polished, “hi-fi”, beautiful look when in standby mode. Bright green busy LEDs bouncing off fake gold buttons scream Yorx and Emerson when turned on.
3 – Yamaha. Basic, blue-collar, non-offensive, “I’ll just stand in the corner”, wallflower looks.
3 - 1 – Pioneer. Simple, elegant. But a little too plastic looking.
4 – Sony. “Hey, did you get that at Best Buy?”
Connectivity
1 – Harman Kardon. Very nice, full of everything. HDTV bandwidth for component switching. Main amp input. S-Video output exhibited noise…not seen in other receivers (using same TV and cables of course)….probably a defective unit.
2 – Pioneer. Plenty of everything. Component switching, 7.1 ch input, plenty of digital i/o….very nice.
3 – Yamaha. More than I ever need but not quite as much as the Pioneer.
4 – Onkyo. No component switching. Enough of everything else.
5 – Sony. No pre-amp out…nuff said.
Ergonomics:
1 – Harman Kardon. Back panel is very well laid out and OSD is intuitive.
1 – Onkyo. Ditto
3 – Yamaha. Nothing to right home about
3 – Sony. Ditto
4 - No OSD and back panel layout is a maze.
Notes:
The H/K only has 5 channels of power…but each channel is assignable.
The choice:
If I didn’t have an amp, and I was concerned with music over movies, I would stick to the Onkyo.
If I didn’t have an amp, and I was concerned with movies over music, I would choose the Yamaha.
As it stands, I do have an amp…a Sherwood Newcastle 9080, so my choice is as follows…
The decision I had to make was really only between the H/K 520, Yammie 5560, and Pioneer 811S. The Onkyo didn’t really count as it doesn’t meet the 6.1 qualification. I still prefer the Onkyo for music and plain ole 5.1 DD/DTS tracks (though I do prefer DD-EX/DTS-ES Matrixed over 5.1) so I intend to keep it for a long time as a secondary receiver. The Sony was never in the running either as it had no pre-outs. These two receivers were compared just for some reference.
The H/K quickly dropped out of the decision because of the lack of DD-EX (huge factor), distracting front display in a dark room, horrible remote, high price, and perceived low build quality. I’m honestly pretty worried seeing the high number of H/K refurbs out there.
So the real choice is between the Yammie and the Pioneer. I’m slightly leaning towards the Pioneer because of DTS-ES Discrete, but I honestly can’t say that those 4 movies with DTS-ES discrete are worth it. I do feel the Yammie is more solidly built and people rave about it’s reliability, whereas I’m more skeptical with the Pioneer. If I listen to 2-Channel music more often, I would more likely lean towards the Yamaha. Having the Newcastle 9080 amp drive the NHT makes that music gap much closer than in the above comparison. As it stands, I’m 50.1% in favor of the Pioneer…but I’m going to hold onto the Yamaha until as long as possible and my decision might change in the next hourJ.
BTW, if the build quality of the Onkyo SR700 were as good as the 676 and the 2-channel music performance were the same as the 676, I’d grab it in a heartbeat. Too bad it’s a little more than what I want to pay ….
BTW2, I desperately wanted to keep the H/K. H/K in my mind as an aura to it like Jaguar does in the car world. To me, it just seems further from the mass market brands. But just like the Jaguar, reliability, build quality, and underperformance lies under the hood of those sleek lines. For a receiver of this price to not include DD-EX and a 6th channel is inexcusable, IMO. The mystical qualities of the H/K amps were lost on me, as they seem to distort the music to the warm side. I prefer that the sound is neutral rather than biased to any side. They
Fronts: NHT 2.5i
Center: NHT AC-1
Sides: HTD Level3
Rear: HTD Level3
DVD: X-Box
2 – Yamaha
3 – Pioneer
4 – Harman Kardon
5 – Sony
2 – Pioneer
2 – Sony
6.1 performance
Remote
Looks
Connectivity
Ergonomics:
1 – Onkyo. Ditto
3 – Sony. Ditto
Notes:
The choice:
