I just recently remodeled my basement to include a home theater system. Initially we were using my girlfriend's old Panasonic HTiB and her Sony Projector, along with my FiOS set top box and another Panasonic Blu-Ray player. Thinking I was being slick (you probably know where this is going), I ran a 50' HDMI cable (Aurum) through the ceiling before it was drywalled so I could connect to the projector from an HDMI switch that I had the FiOS and Blu-Ray connected to. Naturally, when I got everything hooked up, I didn't get a signal to the projector. I did some research to find that HDMI had a soft-limit of 15 feet, and that I would need to boost or repeat the signal somehow. So I added a Tripp-Lite Signal Booster/Repeater (24Hz) near the input end (I tried to put it near the output, and that had no effect), and voila! I had signal to the projector for both FiOS and the Blu-Ray player. Since the HTiB was a piece of junk, I replaced it with an Onkyo TX-NR509 receiver. I brought the FiOS and Blu-Ray into it, and had the HDMI out to the Projector (with the Tripp-Lite Booster still in place), and again, had no signal. FiOS wouldn't even register - the Blu-Ray player tried to connect, but then I got a 'Frequency Out of Range' message from the receiver. Interestingly enough, I could view the On-Screen menus for the receiver, and when I hooked up my Motorola tablet via HDMI, I got a signal - but no luck with the Blu-Ray or FiOS. I contacted Onkyo customer service, and they pretty quickly narrowed in on the long cable and suggested I test the receiver with a short (5m or less) cable. So I grabbed my little 20" flat screen from the office, hooked it up with a short HDMI cable, and everything worked beautifully. Still needed to get to the projector, so I researched repeaters and boosters, and settled on the Ultralink HDMI Repeater (which was almost $200). Put that in place near the projector, and FiOS works beautifully! Unfortunately, I'm still getting the 'Frequency Out of Range' message on the blu-ray player. Any suggestions? My initial thought is to put a stronger booster in place where the Tripp-Lite is (is there such a thing? Tripp-lite also makes a 60Hz version - would that likely make a difference over the 24Hz version?), or another repeater. I'd really like to avoid ripping through the wall and ceiling if possible. My next step may be to call a home theater professional in - but if I can spend $100 or so on another repeater, booster or something along those lines, I'm willing to try it. As an aside - do I risk damaging either the receiver or the projector by a) using a long cable and b) boosting/repeating the signal? The Onkyo service rep suggested I might be. Thanks for your help - as you can tell, I'm very much a neophyte.
