Dave Nibeck
- Feb 23, 2000
Getting ready to embark on panels. I see most people use pegboard. Would there be a benefit of using homosote (sp?) instead?
I would like to go with a darker burlap and don't want the white batting to show.I'm not sure that will be a problem unless you're using a traditional potato sack type burlap. The burlap I purchased at the fabric store is a close enough weave that the white batting behind it is not visible. I'm using a dark green herringbone pattern burlap.
My elementary knowledge of the subject says: wait a minute, if the cloth will not let the sound through to be absorbed, then how can the "panels" do their job?I agree with you, Tom. There are three things a material can do to sound: absorb, reflect, or transmit it. Any combination is possible, depending on the material. Now, if a covering fabric fully transmits sound (is acoustically transparent), then the thick absorption material behind it can work.
If, on the other hand, the fabric doesn't transmit sound well, it must be absorbing it, reflecting it, or some combination thereof.
A typical 1mm or less thickness of fabric is not a good absorber in the audio range. It is too thin compared to even short wavelengths of sound to affect them. You need more like 1/4 inch (6mm) of thickness to have a significant effect.
So thin, non-transmissive fabric is going to reflect sound, making it a bad choice as an absorber covering.
Terry
A typical 1mm or less thickness of fabric is not a good absorber in the audio range.Right. But it will absorb some. What TW was alluding to was that fabric that has some absorption is better for a sound absorbing panel than totally transparent material.
Highly unlikely any soft fabric would reflect sound.
Pete
