A quick question regarding the HD Discovery clear logo that appears from time to time on the lower right corner of the screen.
I notice that when this appears (I hate these things!) that I don't see all the lettering. In other words, instead of something like "HD Discovery" it's more like "HD Discov" - the right side is cut off. I'm wondering if this is a problem with the transmission or with my set? Incidentally, I'm using a SONY VW10HT 16:9 set with my Dish 6000 player and have always seen correct aspect ratios before from all sources (unless the source was faulty.)
How's this clear HD Logo look to the rest of you with either my set or your own HDTV set? Yes, the aspect ratio is set correctly on my projector - in fact for HDTV sources it's automatic as long as the information it receives is correct. I'm wondering if this has something to do with the fact that DISH is using their HD Demo Channel for the Discovery Preview and the actual station will be using the 8PSK module for the 6000 to squeeze more channels into each transponder.
Thoughts?
Thoughts?
