Matthew BW
- May 10, 2002
I have decided to try bi wiring my speakers. I replaced the jumper with a piece of speaker wire and there was a definate improvement so I figured I would give bi wiring a try. My question is I currently have 12 guage wire run and my thoughts are to run that to the low frequency and 14 to the high or to just get two full runs of 14 per speaker. I can not use two runs of twelve do to constraints at the connector ends. What would be the better choice out of the two options?
