Walt Meger
- Jul 11, 2001
I have a friend with custom installed HT wiring on his new home. The sub has a cubby hole on the opposite side of the room from the rest of the gear. The low level signal cabling has failed and trust me, the only option is to go wireless. Can anyone recommend a 2 channel (L/R) wireless audio T/R system with the appropriate frequency response (~20-200Hz)that doesn't cost a fortune? Thanks
