will I still get black bars on the side with Treasure Planet? (1 Viewer)
david*mt
Since Treasure Planet is in a 1.66:1 aspect ration and a widescreen TV is wider than that, will there be black bars on the sides? It is 16x9 enhanced so I was just wondering.
Ken_McAlinden
Livonia, MI USA
Kenneth McAlinden
It's nominally 1.66:1, but it is actually slightly wider than that. You would have to have less than 3% overscan on either side to see any of the black bars.
Ken_McAlinden
Livonia, MI USA
Kenneth McAlinden
Ron Epstein posted a number of screen captures that demonstrate the size of the vertical black bars in his review of the disc. Here's one:
The actual aspect ratio is in the neighborhood of 1.69:1
You would need less than 2.5% overscan on either side to actually see the black bars.
Seth Paxton
Maybe this screen caps are from a PC using something like Power DVD?
Neil, that's what Ken is implying. That's why he says you would need less than 2.5% overscan to see them. Ron obviously uses PC capture systems that show the full canvas of picture info, including black bars however they might be placed.
DaViD Boulet
Just taking the opportunity to PUSH for Warner and MGM to do 16x9 encoding for their 1.66:1 titles like Disney...
As you can see, there's no problem with typical 16x9 *or* 4x3 viewers seeing any sort of pillar-boxing. The only folks who would see pillarboxing are those with perfectly calibrated (almost 0 overscan) displays which tend to mean tweaked-front projection systems. No problem...those are the folks who *want* to see the bars :)
Cliff Olson
A lot of Disneys seem to have 1.66:1 as well. I've *never* had black bars on the sides unless it's not anamorphically transferred. GREAT movie was Treasure Planet!
Brasspineapple
