John Tompkins
- Aug 30, 2000
On a related note. I a/b tested the difference between my panny rp56 and sony 555es using digital connections, I could hear NO difference.
The way I tested this was to put two identical cds {cranberries} in the dvd player and cd player at the same time, and yes the volume was exactly the same verified by my radio shack meter. I was able at the push of the denons remote to go back/forth between the two units, No differnce that I could hear. Remember this was using digital outs on each player.
One other thing of note . If you are comparing the digital out versues the analog out of your player, remember to db them out to the same volume, as there was a 3db difference between the anoalog and digital out on my unit.. This could be enough to TRICK you into thinking that there was some huge difference!!
