Chris Souders
- Oct 12, 1999
Hi all,
I've recently moved into a house I'm renting. The electric wiring is, I'm sure, not up to par. Most of the outlets are only two prong. The room where I'm putting in my home theater is going to have to have an outlet placed by an electrician. My questions are this... given that my equipment consists of a 27 inch tv (soon to get bigger), DVD, CD, tape, VCR players, Tivo and the Outlaw 7 channel amp and 950 reciever when my name comes up. Speakers are paradigm 100 for fronts, center, and 20's for rears. The sub is pw2200 I think. I'd have to power all this from one receptacle. Questions..
1) What should I tell the electrician to do specifically? Run a new line from the fuse box directly to this one outlet? What amperage? (I may be limited to whatever the fuse box has I Guess...)
2) I'm getting confused reading about surge suppressors, line conditioners, and voltage stabilizers. I think I know what they all do, but how do I know which ones I need? And, more specifically, within each category, which products would you recommend given my future gear. Are there ways to test if I need a line conditioner or voltage stabilizer? I have a monster powercenter hts700 currently that is the only thing everything else is plugged into.
Thanks so much for your help.
Chris
Chris
