I think this is the right forum if you want to buy a screen. But ask in the DIY forum if you want to make or paint one. If your room is not totally dark, you should go with a gray screen. If you want to paint your own screen, a very popular gray color is Behr Silverscreen from Home Depot. I recently painted a new screen using 1/2" thick Medium Density Fiberboard.
Given you have an LCD ... go with a gray screen of some sort either the DIY method or a gray from Dalite or Carada for instance.
If you don't want to fully DIY ... buy the actual screen material and simply build your own frame around it.
Gray screens are great for getting you better blacks, but a high gain screen might be more usable in a room with some ambient light. A Dalight 2.8 gain is very bright ... but at the cost of the blacks and the viewing cone is more limited.
Michael TLV: In your post, you recommend a grey screen for a LCD. I'm currently using black-out cloth (110") with my Panny 700. If I purchase a High Contrast Grey Carada (a forum sponsor) 110" screen for $640, will the blacks of my 700 equal the blacks of my previous HD display; a Toshiba 52HM94 (HD2+ DLP)??? If so, I'll order one tomorrow. The only issue that I have with my black-out cloth/700 combo is the "fog" that I see in the dark scenes of my favorite HD dramas. Bottom line: by spending $640, will I "turn" my Panny 700 LCD projector into a HD2+ DLP projector??? PS: I have a dark room.
No ... you cannot turn that LCD unit into a 2+ because you will still have vertical banding and non-uniform colours across the screen surface which is inherent in your LCD.
Good DLP front projectors have much better blacks than those RP DLP based units primarily because of the lack of a lenticular screen.
I have no idea about how blacker the blacks would get ... but a typical 2000:1 DLP will have better blacks than a 2000:1 LCD. (Probably because one maker is exaggerating their CR numbers.)
Thanks for the info, Michael. Obviously, my purchase of the Panny 700 was based on the price of the projector. I haven't seen any VB on my unit after 1,077 hrs, and to my eyes, the colors are great. IMO, it's the blacks that prevent the Panny 700 from being a SUPER buy. Apparently, a screen alone won't correct this. I'll pass on the screen. You have just saved me $640 and/or the trouble of returning the screen, which wouldn't do neither Carada or myself any good. I just did a price check and found that the IF 7205 is still too expensive for me at about $4100. If the price drops to $3,500, I'll sell my 700 and buy one. I guess you get what you pay for. I would like your opinion of the IF 7205. Thanks again for your advice.
