Wayne_T
- Jun 15, 2001
My Yamaha RX-V3000 receiver has a center channel graphic equalizer adjustment, +/- 1-5 dB at 100, 300, 1K, 3K and 10K Hz. The manual says that this feature is used to match the center speaker tone to the right and left mains tone. The center does have a very noticeable difference in tone when I play the Yamaha pink noise test tone. I think this is caused by the center speaker placement - on top of a 56" RPTV, which probably emphasizes the mid to upper bass region a little too much. I have also read that this can affect dialogue clarity on some DVD's, which we have also experienced.
My trail and error approach to the center EQ adjustment hasn't worked out very well. Is there a procedure that I can follow to set up the center eq properly? I'm thinking that test tones at the 100, 300, 1K, 3K and 10K points would be the way to go, but I don't have a source for these. Have any of you successfully done this set-up and can you share your methodology?
BTW, the center speaker is a Paradigm Studio CC and is driven by an Anthem MCA-3, mains are Studio 60's driven by a Bryston 4B-ST. I have an RS SPL meter and an AVIA calibration disk.
Wayne
(also posted on AVS)
Wayne
