Jim A. Banville
- Jun 20, 1999
Okay, when I put up the flashing blue color bars from AVIA (Panasonic RV31 connected via component cables to Sony KP-53HS10), I only adjust the COLOR control and am able to get all four bars/patches to match (the COLOR setting is about in the middle). When I go to the red color bars I am able to get all four color bars/patches to match just using the COLOR control (the COLOR setting must be lowered slightly compared to blue). BUT, when I try to do green only using the COLOR control, I can't get the yellow and blue bars/patches to match the blue/white bars/patches. The only way to get all four bars/patches to match is by adjusting the HUE control about 1/3 from center towards green. Does this mean that the color green is "wrong"? I tried this on two different Sony KP-53HS10's and they reacted the same. I haven't tried this test with another DVD player, so I guess it is possible that the Panasonic is doing something funky to the green color.
thanks
Jim
Jim
Mancow rocks! Link Removed
thanks
Jim
Jim
