Chris Tedesco
- Aug 26, 2002
- Chris
Ok,
Just went through the brightness section a couple of times and am not really sure if I followed the instructions correctly.
In regards to the 3 vertical brightness bars on each side of the fuge, (sp?) Am I supposed to see any of them? Right now I have it set so the 2 closest to the fuge are barely visible.
This is the 2003 version and I must say it's a little more techy then I would like. So if anyone knows what the correct setting is for brightness, I'd appreciate your help.
thx
thx
