patrickMO
- Jul 25, 2005
I built my htpc last year and through various changes in life just recently began using it. Come to find out that the Radeon AIW I purchased back then isn't supported in MCE2005 as a capture card. Basically ATI said "sorry buddy, but you can buy another card from us".
My question is, should I go with something like the Hauppage PVR 150 as my capture card and keep the AIW, or go with the AIW Elite Pro, which from what I can tell is what I would need.
Thanks!
Thanks!
